pump flow in the model (it is double from the one in the curve pump)
r.voicu
1
hi, i have a problem with creating a water supply system, in the pump, flow in results is double compared to the one in the pump curve). I specify that in the model the demands are correctly introduced in nodes but the network flows are crazy compared to the situation in the field.
I also attach the .inp file, maybe someone can help me
thanks
 https://files.engineering.com/getfile.aspx?folder=e3000c13-5b45-4e19-b7b2-80c35fc489cb&file=watersistem.inp
How about a file that is easily opened.
How about to walk your model in the field and verify if the input data is consistent with he field conditions.
