ben3929
- Jan 20, 2010
- 35
I am working on a project to design a bolt connection for wide flange beam seating on HSS column (cap plate). While checking the prying action on the beam flange I got a result that the minimum required thickness is twice greater than beam flange thickness. There is no room to put in additional bolts to my connection. Would it be okay if I weld a plate to the beam bottom flange to increase the thickness. Plate weld will be only at the connection area not through out the beam length.
