NZMark
- Nov 1, 2008
- 32
Dear All,
I am trying to add some variable values from a part to the callout text in a draft.
But Solid Edge simply crashes (error written further down in this post).
Could someone please see if they can reproduce the following?
Make a part, say a single protusion with a name (e.g. "diam") for the diameter in the variable list.
Then make a draft, select the Callout text tool, click on Property Text bar. Under "Named Reference" (or any of the options below it), the variable "diam" should be visible.
Then I select "diam", click Copy and I get the error
"Solid Edge is being closed because the system memory is low" (and it closes...)
System: SE V20, XP 64-bit, 8 GB RAM (shouldn't be any memory problems!)
Am I trying to use the Property Text command correctly?
Many thanks, MT
Many thanks, MT
