Problem of assign effective length for StaadPro Analysis
neaveyoung
23
Hi All,
I have used StaadPro to do steel analysis. But i have some problem in assign the effective length of column. I have assign KY=2.0 and KZ=2.0 but when i check the design output the buckling calculation effective length still the same ==> K=1 . However the effective length under section property has change to (column length x 2.0).
1. Is there any mistake i use or assign in the staadPro ?
2. Why effective length under buckling cal. still unchanged.
3. I also have doubt should i assign Ly , Lz or KY, KZ
I attached the model and one of the calculation page for column which highlighted the effective length i have mention for your ease understanding.
Thanks in advance if anybody can assist me for this matter.
Your reply is much appreciated.
 https://files.engineering.com/getfile.aspx?folder=40df856c-dad4-4c2c-af55-9e7b88cf21dd&file=Engineering-1.zip
Under what code? Note that beam-column design equations include checks for K equal to the design value, as well as K=1. You've also not assigned Kx, which is probably controlling
Agree that you need to assign Kx. X is the longitudinal axis.
All I know is P/A and Mc/I
