gearman1234
- Dec 3, 2002
- 104
We have to shape 8/10 DP, 25 Deg, 4.8 ID, 5.313 Maj Dia , 40 Teeth Internal gear.This gear is being shaped on TOS OHA 50B gear shaper. It is observed that the shaper cutter is getting rubbed on the trailing edge clearance face. After checking all possible reasons, we have zeroed in on one reason. During the return stroke the cutter should retract obliquely at a set retarction angle. The sense of rotation of cutter during retraction should be the same as that of the internal gear or cutter(since both have same sense of rotation in internal shaping)
But actually the sense of cutter rotation during retarction is opposite to that of gear/cutter rotation, thereby causing the interfernce of trailing edge with the gear tooth flank.
What is the solution to this problem? Is it related to software or a mechanical problem?
