PhilEduard
- Aug 24, 2004
- 36
I thought quickly this could be easy but it seems to give me a bit of confusion. Where you realized a pressure thrust exist, you simply multiply the inside crossectional area of the pipe with its operating pressure and, that is if the change in direction is 90 degree. How do you evaluate this figure if the chage in direction is other than 90 deg, (less than 90 degree)? Thanks for any help.
Phil
Phil
