bmodrow
- Jan 31, 2003
- 15
I have little to no expertise in this area and was hoping I could receive some guidance. I have seached the forum regarding PF correction capacitors and have not came up with any solutions.
I have a customer that has some power factor correction capacitors across the feed of two air handeling units. The customer says that he recently lost some capacitors (I'm thinking due to age)and would like us to do a power quality survey. From what I am told these capacitors are are across the line at all times (wether or not the air handelers are running).
Can someone please give me some direction as to what possible problem causing areas, I should be looking for after we have collected data for a few days.
Any pointers will be greatly appreciated.
Thank you in advancne.
