MikeT14
- Feb 15, 2005
- 32
I'm designing a two-story parking garage using post-tensioned beams and slabs. It will be ordinary moment frames with three nominally 62' spans in one direction and 7-9 spans of between 22' and 32' in the other direction. My one-way slabs range in thickness from 7" to 9" and run in the short (22-32') direction.
My question is in regards to those 22'-32' beams running parallel to the slab. During a meeting with a PT supplier, they mentioned that you need to post-tension the beams parallel to the one-way slab to the same P/A value in the slab. I've searched though my mountain of literature and can't find a reference or guide to this situation. My question is this: How much slab do I consider in the design of those beams? Will I be accumulating prestressing if the slab is already prestressed to a P/A value and then I add more through the prestresssing of my beam?
Tech support at ADAPT stated that it didn't matter as long as my tendons were anchored at the CG for the tributary cross-section. Well, the tributary for my cross section is 31' or 62'! Should I just be using the area and CG of the beam itself? I'm worried that I will be introducing a significant moment in the beams if the tendons are anchored higher/lower than they should have been. As these beams aren't carrying a significant gravity load except selfweight (since they're parallel to the one-way slab), I'm concerned that they wouldn't be adequate if a moment did develop.
Any help or insight would be appreciated.
