Positive displacement pump
MECE02
Chemical
Mar 12, 2009
18
A recent safety review was performed. Here is the scenario:
1000 gallon plastic tank containing amine
If the vent were closed and the positive displacement pump (small pump, maybe a few gallons per hour)is running could it pull enough vacuum to damage the tank?
I don't think this scenario is credible because I wouldn't expect a liquid pump to pull vacuum. Do you agree?
Thanks!
I think is´possible that scenario; in my experience I have seen plastic containers with 250 gallons of capacity collapsed because of vent closed and bottom valve open.
Why not ask the pump Vendor if his pump is capable of pulling a vaccuum.
Little pump over time = loss of liquid with vent "CLOSED" the time is your variable. At some point your tank will collapse without air or other vapor to displace the volume removed.
Read API STD 2000.
"We don't believe things because they are true, things are true because we believe them."
