Position tolerance from a single datum 1
JoeBlock
Automotive
May 31, 2005
30
The axis of one hole, which is the datum, to another hole.
The feature control frame says 0.1 to [-A-],[-B-],[-E-]. A 42.5 Basic leads from diameter A-E to the perpendicular center axsis of the other hole.
For purposes of capability studies does the 0.1 mean the entire tolerance zone? And if that is the case should the delta between the true center and the datum be doubled.
Maybe I was a bit wordy. Do I double a position tolerance even if it is from one datum, not diametrical?
You could try the Drafting Standards & GD&T forum. Lots of bright minds there.
Good link, thanks
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
