simasa
- Sep 25, 2007
- 30
I want to use a PSD (Position Sensitive Device) and a laser beam for the position measurement. Laser beam will be stationary and PSD will be moving (50 mm/s).
PSD’s are available in different sizes (4 x 4 to 20 x 20) mm. Bigger the size of the PSD, less the resolution and accuracy. It is mainly due to more noise in the signal for bigger PSD surface. Position resolution may also depends on some other factors like stability of laser beam.
From one corner to other of the PSD; a voltage signal of 1-10V. To get the position resolution of 1µm, about 1 mV signal must be readable for 10 x 10 mm2 PSD. Its mean noise should be less than 1 mV.
Now there is no theoretical way to calculate reliable resolution and accuracy of such an application. One should try.
Before I try, perhaps some one could benefit me from his experience.
Which maximum resolution and accuracy can be achieved from this setup?
simasa
simasa
