Please enter an Integer between 2 and 256 1
uGlay
389
Does anyone know why i get this error message? I was getting it 2008 and now that i upgraded to 2009 i am getting it still.
What worth is this software if i can only make parts with 2 decimal places of precision? Any help is appreciated. Hopefully it's just a computer setting and nothing major.
SW2009 Office Pro SP2.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Not sure this is it but try changing your decimal places to 2 under "Angular Unit". Your pict shows it set to 1
I should have clarified, the angular units can be changed to any number but the Length Unit decimal places cannot. They're stuck at 2.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Must be your install. I can change to 8.
Can you explain step by step how you arrived at getting the error message.
-I hit M to measure something.
-Click on "units/precision" button on the measure toolbox.
-Click on 'up' arrow of Length Unit Decimal Places.
-Click OK
-Error message appears. "please enter an integer between 2 and 256"
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
I get the same error message...
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
well, i googled but there's nothing.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Perhaps you and Jeff should compare computer specs, software, add-ins, etc, to find commonalities which could be causing that glitch.
Maybe just try resetting the registry first.
faq559-507
Maybe try typing the number in the box versus using the radio control?
Reaper.
i tried all suggestions in this thread (except comparing computers with jeff) and none of them worked.
There is an option to use document units though, so I enabled that instead, then went to tools, options, document properties, units and changed the precision from 2 decimal places to 3 decimal places.
the problem went away. so now i can get whatever precision i like. kinda crappy that i have that glitch though. up until now i never cared enough to look into it but i needed 3 decimal places and finally looked into this.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
uGlay, I was having the same problem as you. I installed 2009, and could change the precision with no problems. Then all of a sudden I was getting the error you were getting. Nothing changed with my install.
Your solution worked for me as well. I would have never thought of doing what you did. Thanks for the help.
Glad I could be of help.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
