jvian
Aerospace
- Aug 13, 2009
- 119
Until recently my facility has had third party support for developing and managing our test lab but the company is going out of business and we are attempting to take ownership of our own lab software and equipment. Our stands test various fluid components (pumps, valves etc.) where we monitor various sensors for pressure, temp, flow etc. and we control and monitor the system using a PLC/HMI setup. Currently we are using an Automation Direct DL205 PLC, TopServer OPC and WonderWare InTouch HMI and for most testing we have been very satisfied with the capabilities. Recently we have been asked to perform some more transient type testing and will need to monitor our sensors at a higher rate than normal. We need to be able to monitor our sensors on the order of 100-200ms and right now can only achieve 400-500ms which seems slow based on my research of PLC's in general.
My question for you folks:
1.) Does this seem reasonable to ask or are we asking too much for our current hardware/software?
- if not realistic for my current setup, what are some low cost alternatives (PAC?)
2.) What are common logging rates for other users?
3.) What factors directly influence logging or update rates? (very broad question I'm sure)
4.) We do have to perform a bit of math to manipulate our sensor data - is math better performed in the PLC or in the HMI?
- our support tech always seemed to believe it was all limited by InTouch and put much of the math in the PLC
I am personally familiar with the InTouch programming and can handle most if not all functions with regard to scripting and have been experimenting with TopServer as well. I do however have limited experience with the PLC ladder logic, though I'm confident I can churn through it and learn it as I have been educating myself with it for several weeks now and it seems fairly intuitive. Any advice would be great as to what some options are or how to proceed to better understand my logging capabilities. Again I am learning rapidly as I go but I do have some background in programming and was involved in the complete development of the test stand and feel this is a task I can bring in house over time. It is becoming too costly to wait (sometimes days) to get support when one of our production stands goes down.
Thank you in advance for your assistance and hopefully I can promptly answer any questions any of you may have.
- J -
- J -
