xyzz
- Mar 14, 2003
- 126
Using currently Mitsubishi FX1N/FX2N, I need for some projects a faster PLC (meaning shorter scan time).
The ideal choice must meat at least all of the following:
- Be a single-unit enclosed PLC with 24VDC power and transistor outputs.
- Be expandable.
- High-speed inputs on the main unit capable to support at least 2 quadrature encoders.
- At least 2 high-speed outputs on the main unit.
- On-line editing feature is a must.
- Typical scan time <=2ms per 1000 program steps.
Any suggestions will be greatly appreciated.
Please do not suggest PLC missing any of the above.
Thank you.
- Be expandable.
Thank you.
