Guest
*TITLE 'EXFE01 - PLANE STRESS CANTILEVER EXAMBPLE'
STRUDL 'EXFE01' 'PLANE STRESS CANTILEVER EXAMPLE'
$* ** PROBLEM DESCRIPTION: Sample problem for Finite Element Analysis.
$* ** This problem is similar to example 'FE-1'
$* ** in the GTSTRUDL User's Manual, Section
$* ** 2.3.9, Volume 3.
$ 2 BY 8 MESH
UNITS KIPS INCHES
TYPE PLANE STRESS
$ USE GENERATION CAPABILITIES TO GENERATE 27 JOINTS
$ GENERATE ALONG X-AXIS, MODIFY ALONG Y-AXIS
GENERATE 9 JOINTS ID 1 3 X 0.0 6.0 Y -6.0 0.0
MODIFY 2 ID 1 X 0.0 Y 6.0
$ GENERATE 16 QUADRILATERAL ELEMENTS
GENERATE 8 ELEMENTS ID 1 2 FROM 1 3 TO 2 3 TO 5 3 TO 4 3
MODIFY 1 ID 1 FROM 1 TO 1 TO 1 TO 1
CONSTANTS
E 30000.0 ALL
POISSON 0.30 ALL
CTE 0.9E-05
ELEMENT PROPERTIES
1 TO 16 TYPE 'IPLQ' THICKNESS 1.0
$ APPLY A PARABOLICALLY VARYING END SHEAR LOAD
$ TOTAL LOAD EQUALS 40 KIPS
LOAD 1 'END SHEAR OF 40 KIPS'
JOINT LOADS
25 27 FORCE Y -4.0 $ EQUIVALENT JOINT LOADS
26 FORCE Y -32.0 $ EQUIVALENT JOINT LOADS
$ APPLY END LOAD USING EDGE FORCE CAPABILITIES
LOADING 2 'EDGE FORCES'
ELEMENT LOADS
$ USE EDGE LOAD FOR END SHEAR.
$ SINCE IPLQ IS USED, ADJUST PRESSURES SO TOTAL LOAD =40 KIPS.
$ A FINER MESH OR AN EIGHT NODE ELEMENT SHOULD BE USED TO MORE ACCURATELY
$ MODEL PARABOLIC LOAD.
15 EDGE FORCE EDGE 3 GLOBAL VARIABLE VY -6.6667 0.0
16 EDGE FORCE EDGE 3 GLOBAL VARIABLE VY 0.0 -6.6667
$ APPLY A CONSTANT TEMPERATURE CHANGE
LOAD 3 'TEMPERATURE LOAD'
JOINTS 1 TO 27 TEMPERATURE CHANGE 100.0
STATUS SUPPORT 1 TO 3
JOINT RELEASES
1 3 FORCE Y
STIFFNESS ANALYSIS
OUTPUT ORDERED
LIST DISPLACEMENT ALL
LIST REACTIONS
LIST SUM REACTIONS
LIST STRESS ALL
CALCULATE AVERAGE STRESSES PRINCIPAL STRESSES
LIST ELEMENT FORCES ELEMENTS 7 8
CALCULATE RESULTANT FORCES CUT 1 JOINTS 13 TO 15 ELEMENTS 7 8
FINISH
$ 2 BY 8 MESH
UNITS KIPS INCHES
TYPE PLANE STRESS
CONSTANTS
E 30000.0 ALL
POISSON 0.30 ALL
CTE 0.9E-05
ELEMENT PROPERTIES
JOINT LOADS
ELEMENT LOADS
JOINT RELEASES
1 3 FORCE Y
STIFFNESS ANALYSIS
OUTPUT ORDERED
LIST REACTIONS
LIST SUM REACTIONS
LIST STRESS ALL
FINISH
