Mobil
- Jan 5, 2005
- 3
I have an application that pivots no more than 3°, but has a high exposure to dirt and water. The loading is reasonable and almost entirely radial. However, there is some impact loading.
I would normally use a loose fitting hardened steel bushing and grease daily with a lithium based grease not considering the extreme environment.
Perhaps my corrosion and wear concerns are unnecessary given the minimal amount of pivot.
Is there a better choice than a greased hardened bushing? I'm also trying to keep the cost down.
