Piping out of roundness 1
John Jones
16
Does anybody have practical experience on out of roundness of piping assessments? A damaged/ dented stainless pipe is causing some issues. The design code is ASME B31.3
Installed and messing up commisioning with disagreements.
Definition of dent or damage is notoriously difficult.
Dimensions of the damage or photo would help, but this is often subjective and depends how hard it is to replace or repair.
Hi Little Inch,
Photos not possible, offical photos ect. It's a lenght of stainless with a sharp impact.
I was thinking of a form of damage replication. Get a similar spool and dent it in the same manner. Then hydrotest it, PT and X ray it.
A sharp impact is not a out of roundness.
Replace damaged pipe.
Agree with R6155 .... There is always a problem with understanding the problem when there is a difference in english definitions across cultures.... A dent is not an out-of-roundness ...
When the OP refuses to provide pictures or co-operate in any meaningful way, it slows or stops the problem resolution..
Lets try these:
MJCronin
Sr. Process Engineer
Repair or replace. Not sure what service this is in, but even if you inspect it now and find no anomalies in it, some can develop over time (again, depending on service conditions). Numerous acceptance criteria exist in the pipeline integrity world for dents (size in terms on depth diameter, sharpness, strain level, etc., ASME, CSA, BS, etc.), and fatigue based assessment methods. I would simply replace if it s sharp dent, these are generally the worst as far as strain level and they develop cracking over time. If the job called for new (undented) pipe, I don;t understand why you wouldn't replace it. If not, complete a strain analysis and fatigue analysis based on expected service.
Analyze all you want, dont change the facts. A sharp impact damage should generally be replaced by a full diameter cut out.
