uncivilized
- Jul 30, 2005
- 26
I am working with a very flat site (.5%) I am proposing a series of ponds to detain the water. Each pond will have the same initial water level. The ponds will be several hundred feet apart (>500'). So if my inlet starts at the initial water elevation then the outlet into the next pond will be a couple of feet below the water level if the pipe has a slope. Is there any reason to have a sloped pipe if it is outfalling in a submerged condition like this? Why not just keep the pipe on a 0% grade. I have seen this done before but wanted to get other's thoughts.
