mectub
- Mar 4, 2009
- 22
Hi everyone, i know that if i want to have the deflection number, i must use a node at interest point, but when i'm checking a model a maximum deflection is one of my goal, so is there a way in CAESAR to set a max deflection or max bending stress in order to get a warning?. What if i want to set max bending stress, let's say, 30% of allowable stress and get CAESAR to check this, is that possible?. Or i must check span by other means.
How do you all deal with max pipe deflection using CAESAR?
Another question if you allow me, where do i set CAESAR to use hot elastic modulus for calculations.
