VladChiefns830
Specifier/Regulator
- Jul 14, 2012
- 33
I'm not a PE - I'm involved in the electrical trade. But I'm hoping that a civil engineer can point me in the right direction. There is a code in the National Electrical Code [2014 NEC Article 250.53(A)(1)] that references "permanent moisture level." It reads like this,
"If practicable, rod, pipe, and plate electrodes shall be embedded below permanent moisture level."
My Questions:
1. Is there such a thing as "permanent moisture level?" If so, would it not change due to rainfall, lack thereof, etc.?
2. What document or standard do I go to in order to learn more about permanent moisture level and where to look up the various depths of permanent moisture level for any given area? Or does this depth require some kind of a soil study for that particular piece of property?
3. Can permanent moisture level vary from area to area, or even lot to lot?
Thank you for any help, or if you can at least point me in the right direction.
My Questions:
