bar7h
- Aug 24, 2006
- 15
I am designing a single span 10'x100' Pratt Truss pedestrian bridge. I have created a 3D FE model of the bridge with the two bearings at the fixed-end modeled as "pinned" and bearings at the expansion-end free to translate longitudinally. When I analyze the model under transverse wind loads, I get very large opposing longitudinal reactions at the fixed-end bearings. It doesn't seem like those reactions represent real world behavior since the oversized holes at the bearing plates should allow enough rotation of the fixed-end of the bridge that the anchors will not see those reactions.
Should I design my fixed-end bearings for those large shear reactions or can I model the bridge so only one of the fixed-end bearing points is longitudinally fixed? Thanks for the input.
