LittleInch
Petroleum
- Mar 27, 2013
- 22,567
In the engineering and Disasters forum there is a debate going on about how a 440V board with a bus tie and two incoming transformers should or is normally operated.
The big ship which crashed into the bridge in Marland, was running a 6.6 kV board with 4 generators, only two running, bus tie closed, then feeding a 440V board through one of two Txs connected, which they switched over every now and then. So when one TX tripped for some reason, all the lights went out and the main engine stopped because all the auxiliaries stopped as well
Is that normal?
Is that normal?
