OpenSTAAD
Rahul Leslie
17
I have been trying to extract model details via OpenSTAAD, but it is showing error right from the start (Error 438)... The code is as below
Private Sub CommandButton1_Click()
Dim openSTAADObj As Object
Set openSTAADObj = GetObject(, "StaadPro_OpenSTAAD")
openSTAADObj.OpenSTAADFile "D:\STD-Files\Str7.std"
'==========================NODES===============================
Dim nNodes As Long
nNodes = openSTAADObj.Geometry.GetNodeCount
Dim nodesList() As Long
[highlight #FCE94F]openSTAADObj.Geometry.GetNodeList nodesList()[/highlight]
Dim xCoord As Double
Dim yCoord As Double
Dim zCoord As Double
For i = 1 To nNodes-1
openSTAADObj.Geometry.GetNodeCoordinates (nodesList(i - 1)), xCoord, yCoord, zCoord
Worksheets("Sheet2").Range("A" & (i + 3)) = nodesList(i - 1)
Worksheets("Sheet2").Range("B" & (i + 3)) = xCoord
Worksheets("Sheet2").Range("C" & (i + 3)) = yCoord
Worksheets("Sheet2").Range("D" & (i + 3)) = zCoord
Next i
Set openSTAADObj = Nothing
End Sub
The line giving the error is shown highlighted above ... The function used is as documented:
Please, anyboby, any idea what the problem is?
Rahul Leslie
In a nutshel, I wonder whether the function...
...is working fine, in anybody's experience. In my case, with the VBA code given in above post, it is giving error, saying:
Run-time error '5'
Invalid procedure call or argument
where could I be wrong?
Rahul Leslie
Add
ReDim nodesList(nNodes-1) As Long
before openSTAADObj.Geometry.GetNodeList nodesList()
You also need your For-Next loop to go to nNodes not nNodes-1.
I'm assuming you know you can just copy and paste the STAAD nodes table into a spreadsheet.
