rads
- Jan 24, 2002
- 7
Good afternoon.
I have a gearbox design which is showing signs of gentle incontinence (note NOT incompetence ;-) ).
Oil is seeping trough a sealed bearing (which is way above the static oil level, we thought the "seals" in the bearing should resist the occasional splash of oil but that appears not to be the case).
I think an oil flinger, mounted inside the case, adjacent to the bearing should keep most of the oil off the bearing and prevent seepage.
I presume there is some science to the design of oil flingers? Anyone care to shed some insights?
David
David
