NX9 Save as
RyanVLee
Industrial
Apr 28, 2011
67
When doing a save as of a component in an assembly UG asks you to do a save as on all the open files that have that component, it would come up in the information bar telling you what file you are doing the save as to now. It still asks you but does not tell you what file you are renaming.
Any Ideas?
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.0.19(testing)
If you can think it it can be modeled
As a work-around, in the file rename dialog, pick any existing part file and press OK. It will error out asking for a new name, but then the current file name will appear in the status bar (lower left by default).
You should log an incident report (IR) with GTAC so that they can fix it properly in the next maintenance release.
www.nxjournaling.com
We are filing it with gtac as well but I figured i would ask the world as well. Thanks for the workaround my guys laughed but it works
Ryan Lee
NX 6.0.5.3
We logged this as a PR (2227881) about a month and a half ago.
Log a new PR and quote that PR as an existing one to be added to.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3.4
NX8.5.0.23 -> NX8.5.2.3 & NX9.0.0.19
Has any one found a work around to this my group is asking cause we do this alot and now everone is using NX9
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
We've been told that the NX9.0.2 Maintenance Release will contain the fix. I don't have a date on when it will be released, but I would think it's due shortly as NX9.0.1 was released back in February.
Until then, the workaround I've been using is to look at the information window, as it will update as you work through each filename. Not ideal, but it's a workaround.
Anthony Galante
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.1
I'm running NX 9.0.2.5, which will be the next MR, and when I do a 'Save As' on a Component of an open Assembly I'm now getting the same exact feedback in the statua bar and the listing window as I would get if I had done this in NX 8.5.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
That's great to hear cant wait we do a lot of save as with large assembly's
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
NX9.0.2 Maintenance Release is out now.
Anthony Galante
Gee, it's a week early.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
