NX Postprocessor - POSTBUILDER put the txt file contents into the output of postprocessing result. 1
nxexplorer
84
Hi expert,
Need help, that my customer needs their postprocessor to be linked with some txt file as output. These files are:
1.Header.txt
2.IfNoTc.txt
3.EndProgram.txt
Need help with how to do that in PB, to put the txt file content into the output of postprocessing result.
Thank you,
Maryadi
Jakarta-Indonesia.
One way to get it to work is to output the txt files as a template files.
You could store them in the postprocessor directory.
Then call them in the applicable MOM event by using MOM_do_template_file [MOM_ask_env_var UGII_CAM_POST_DIR]Header.tpl.
