Nx Nastran Angular Velocity
cicciociccio
New member
Feb 8, 2013
6
Hi dudes,
I'm studying micro flapping vehicles.
I need to evaluate the inertial forces due to the angular velocity of the wing during a cycle.
The angular velocity varies in strength and in direction
I found the way for setting on NX Nastran an angular velocity with varying strength but I did not find a way for setting
an angular velocity varying in direction too.
Does anybody have the solution?
thanks
Hello!,
Till I know NX NASTRAN only allows you to define variable static acceleration loads using ACCEL command, which may vary over a region of the structural model.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
separate load cases, for each velocity direction ?
Quando Omni Flunkus Moritati
Hi, thank you for replying.
I tried to give separate load cases for each direction but I can do that only a static analisis,
The SOLUTION 601, which is the Advanced Nonlinear Transient, can analyze only one bodyload per time.
Anyother tip? appreciate it!
