Imadunatic
Automotive
- May 22, 2008
- 5
As long as I've been using the mirror assembly command, I've had a problem in which the solution that appears to be correct is actually out of position by .1 Degrees(ish). When I have noticed this and attempted to find a solution that is correct, generally this is the only option which is obviously close to what I want. Has anyone else experienced this? Have you found a better method to reuse and reposition components across a line of symmetry? We have 4 designers here that use this command; we are currently on NX 8.5, but this goes back as far as I can remember using it.
Any help is definitely appreciated.
Thanks,
Kevin
Thanks,
Kevin
