NX Journal - Reporting the Delta (Component) Distances between 2 Objects 1
jmarkus
377
I was using AskMinimumDist to find the minimum distance between 2 objects in my NX Journal. I now realize that it would be much more useful to get the component (Delta X,Delta Y,Delta Z) distance measurements instead of the true 3D distance.
But, of course, I can't figure out how to do that.
Any suggestions?
Thanks,
Jeff
AskMinimumDist(
Tag object1,
Tag object2,
int guess1_given,
double[] guess1,
int guess2_given,
double[] guess2,
out double min_dist,
double[] pt_on_obj1,
double[] pt_on_obj2
The last two arguments return the co-ordinates of point on each object. You can easily calculate the delta values.
Suresh
Right, I just realized that after I posted the question.
Unfortunately, I also just realized that I was trying to use the delta values because I thought I wanted the distances in the direction of each of the axes for my problem. Once I did that, I then realized that what I actually wanted was the distance between the 2 objects in a direction perpendicular or normal to one of the objects - and that direction isn't always along an axis.
Jeff
Sorry, I really should spend a little more time figuring things out before I post. Here's what I figured out:
Code:
Function MeasObjToObj(Obj1, Obj2)
Dim measureDistanceBuilder1 As NXOpen.MeasureDistanceBuilder = Nothing
BodyFaces() as NXOpen.Face
BodyFaces=obj1.getfaces
Dim face1 As NXOpen.Face = BodyFaces(0)
Dim direction1 As NXOpen.Direction
Dim ProjDist as double
Dim unit1 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), NXOpen.Unit)
direction1 = workPart.Directions.CreateDirection(face1, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.AfterModeling)
measureDistanceBuilder1 = workPart.MeasureManager.CreateMeasureDistanceBuilder(nullNXOpen_NXObject)
measureDistanceBuilder1.Mtype = NXOpen.MeasureDistanceBuilder.MeasureType.Minimum
measureDistanceBuilder1.ProjectionVector = direction1
measureDistanceBuilder1.Object1.Value = obj1
measureDistanceBuilder1.Object2.Value = obj2
Dim measureDistance1 As MeasureDistance
measureDistance1 = workPart.MeasureManager.NewDistance(unit1, obj1, obj2, direction1)
ProjDist = measureDistance1.value
lw.writeline(ProjDist)
measureDistanceBuilder1.Destroy()
Return ProjDist
End Function
Hope it helps someone else.
Jeff
