engineeringguy
- Apr 11, 2007
- 25
I have an application where my client is looking to meter his gross production in a heavy oil field (API 13). Initially, he started with a Vortex meter but the rubbers from the Sucker Rod Pumps are coming down the line and plugging it up. When its plugged, it caused the stuffing boxes upstream of the meter to leak badly. If this type of failure were to occur in the winter time, the lines would be plugged with cold oil and would require quite a bit of work to restore the wells.
Because these will be mounted remotely, it is desired to have as little or no maintenance as possible. (Pipe dream, I know). Aside from looking at a Liquid Ultrasonic or Cidra Sonartrac, what other options am I left with?
"If experience was always the only factor, how would we get to the moon?"
