jalsina
- Jan 25, 2007
- 1
I am building a low-friction linkage, and want to use pairs of attracting and repelling permanent magnets to provide a calibrated amount of preload to the linkage. As the linkage moves, the distance between the magnet faces will change a total of 3mm. I need the difference in force between the "close" position and the "far" position to be roughly 35 grams. I'm thinking about using small neodymium magnets glued on the ends of adjusting screws. What data do I need to calculate force at a given distance, and what is the formula? What difference will it make if the screws are plain steel instead of non-magnetic material? Thanks.
