Need gearing suggestions for winch
tdw
23
I'm building a winch system with a 16" dia. drum (single wrap). The winch is required to lift a 3600# load at 20 FPM. The maximum speed of the winch is 105 FPM.
My Hydraulic motor runs at 660 RPM (max)and requires a minimum of 7:1 gear ratio to achieve the specified torque.
I was going to use 5DP spur gears, 2" wide, (10T to 140T) to drive the drum, but now I'm worried that they won't be able to handle the torque.
Any suggestions?
I hope you realize that a 140 Tooth 5 DP spur gear has a 28" pitch diameter. That makes a big housing. Have you considered a double reduction or a worm and worm gear drive?
Shopguy,
You're right, the large gear was really 70T not 140T.
I've decided to go witha Fairfield W2B3 torque hub. It's much more expensive but more reliable in the long run.
