Chancy99
Computer
- May 13, 2002
- 104
Well dang it. Didn't quite read the datasheet closely enough.
I have a car datalogger design that uses the DG333A quad 2>1 mux switch to multiplex the 16 input signals to 8 opamps for signal scaling for the ADC. The part I didn't notice was the voltage limitation on the signal inputs ...
They can only range just above/below VCC and GND. Since the datalogger is a 5V system, that kind of clobbers it for measuring vehicle 12V and above signals
The DG333A was chosen for the nice low 25ohm R-on value, and the fact that it had 4 switches in one package.
So, before I set about redesigning the analog input section, does anyone know of a quad (or any) 2>1 mux switch that can handle higher input voltages ? Those inputs are fed via 180k resistors, so the total current is quite small.
If not, I have to rethink the analog input design strategy. The requirement are :
16 inputs
jumper selectable input ranges (0-5V, 0-14V and 9-14V)
feed to 8 ADC inputs
I suppose I could put the opamps up front, and feed their outputs to the mux switches, but that doubles the opamp footprint, along with the attendant scaling resistors etc
Dean.
16 inputs
Dean.
