dcasto
Chemical
- Jul 7, 2001
- 3,570
My colleagues and I remembered seeing a video, well an 8mm film, of a lab where they had glass tubes to show you what happens in multiphase flow.
One of the most interesting was the split flow. When a two phase flow in a line comes to a tee branch the flow can go straight, or take a 90 turn, almost all the liquids took the turn at the tee. They would vary the split and sure enough, when 10% of the flow took the turn, almost 90% of the liquids went with the 10% of the gas.
We actually are seeing this. One engineer built a "unique" slug catching facility that had a tee arrangement in it. The 12" line had a tee branch It didn't work out quite right so the field just runs the 2 12" lines open all the time. Guess what, those 2 lines each have a separator and the separator on the line that took the 90 turn is always flooded and the dump valve cannot keep up.
The question is; has anyone else run across this old video, We'd like to give it to our field people to show them what is happening. I've looked at youtube, no luck.
