Multibody problem in SolidWorks 2007
serdart
26
Hi all,
In SolidWorks 2007, I'm trying to save an assembly as a multibody part. As the tutorial says, I'm opening the "Save As" dialog box and click ".prt, .sldprt" as filetype.
The tutorial in "Help" says that 3 check boxes below should appear, but they don't!
Exterior Faces
Exterior Components
All Components
When I continue and save the assembly as part and make a drawing sheet of it, I can not create section views.
Is there anything that I'm missing or wrong? Why dont the 3 checkboxes appear?
thx
The newer versions have those three options to check. In v2007, I think there is an "Options" button to hit when you try to save as a part file. If so, select "all components", and when it asks whether to resolve hidden/suppressed parts, refuse that (or it will save every body in your assembly, regardless of what you have shown/resolved).
This should save a multi-body part file that can be sectioned, since the bodies will be solids instead of surfaces.
Jeff Mowry
A people governed by fear cannot value freedom.
Save your assembly first and then again do a save as and select type as part, you'll see the 3 options.
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
