Multi Row single segments with Position and Perpendicularity
R1chJC
Marine/Ocean
Apr 15, 2015
51
Hi All,
I'm looking at a drawing the below call-out on a hole - doesn't seem to make sense to me..
Isn't the first row redundant since you get that same control as part of the Position tolerance row anyway?
Datum feature A is a face perpendicular to the hole.
Yes, the perpendicularity should be a refinement of position if both are specified. In your case it is redundant.
And if someone will be revising the print, you should probably have them add a diameter symbol before each of those numbers (which are very small numbers, by the way!).
John-Paul Belanger
Geometric Learning Systems
