Guest0527211403
- Apr 24, 2004
- 1,125
Hi everyone
I am working on an assembly and we are using Layouts to declare key sizes.
I want the layout to have multiple sheets.
Sheets 1-3 are a title page and some preliminary information and calculations linked to Case Study sketches via relations.
Sheet 4 is where I have the Top-Level assembly mocked up and important dimensions laid out. I created a table with a repeat region to lay out the values on this page.
Sheets 5 and on are to spell out important dimensions from each subassembly, some controlled by relations linking them back to numbers processed and output on page 3.
Now, here's the rub. When I try to make a table like the one on sheet 4, I get ALL the dimensions from the layout showing up in the table. And as I create dimensions on page 5, they show up on page 4's table!
Is there a way that I can tell the repeat region to only show dimensions that are on the same page as the table to which it belongs? I can manually filter everything that's not supposed to be there out, but this is going to be a real pain once I get further into the layout.
I want to avoid multiple layouts, if that is possible.
I'm hoping that this isn't working just because it's Monday morning...
Thanks in advance for any ideas![[smile] [smile] [smile]](/data/assets/smilies/smile.gif)
