Move an embedded chart on a worksheet to a chart sheet with VBA 2
bacon4life
1,530
Does anyone know how to move an embedded chartObject from a worksheet to a separate chartsheet with VBA. Manually I would just right click and select move to new sheet but I can't find an equivalent VBA command.
Since it is a chartObject, I can't use Charts.move. Chart.add will create a new chartsheet, but I can't figure out how to move the chart from Sheet1 over to the newly create chartsheet.
This will work if the chart is active. If not, replace "ActiveChart" with the name of the chart object.
ActiveChart.Location Where:=xlLocationAsNewSheet
Have you tried the macro recorder with your operations?
TTFN
faq731-376
7ofakss
