Motor control 1
Abdoudiallo
Industrial
Jan 13, 2009
6
Goodmorning
I wanted to have some help here.I work for a compny and we have two motor that conected to a baldor driver.And when they both run I can hold one motor.What is the problem The gear box is ratio 5 and both horsepower motor is 1/3.
There is some missing information here. Do you not have enough torque to turn the load? I had the same problem one time because the mecanical engineer put too small of a gear ratio. To get the driven speed that we needed the VFD had to be turned down so far that the motor lost torque. Keep in mind that most drives cannot supply torque below 15 percent of the nameplate RPM.
Actually, start before that.
AC or DC?
Assuming AC, Standard motor or Servo?
Are the motors identical?
Vector control or V/Hz? (Hint, you cannot implement vector control on multiple motors off of the same drive).
Clutch or other mechanical slip device between the motor and the shaft you are grabbing?
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> faq731-376
Hi it an AC drive Baldor brand 1/3 hp bothe motor are identic the only difference is the gearbox.But I have put in an other line two motor with difference gearbox but with a allen bradley vfd and I didnt have that problem.I could not hold any of the motor.
