brainteaser
Computer
- Jun 21, 2005
- 2
Hi all. I am new here so I will introduce myself a little before I address my problem.
I am a Computer Engineer (well almost.. about to have a degree). I am currently working in a Psychiatric Sleep lab as their systems expert.
We are in the midst of reforming an experiment. The basics of the experiment are to study sleep deprevation in pigeons. The way we sleep deprive them is by using a conveyer belt to move the bird a bit if it is beleived they are beginning to sleep.
Up till now we did this using SpyVision or something like that. But, I have been given access to 3 different cameras
Pixord 126n
Axis 2420
IQeye (cant remember the number)
all of which have an internal motion detection which can then send a relay signal out. Supposedly it can be DC but I have been having a problem getting it.
What I can get is about a .05mV AC difference on the Pixord.
I am in contact with Pixord to see if this is correct but here is what I would like help with if anyone can.
I know little about motors. I will need to use this signal to trigger some sort of motor to move the conveyer to wake the bird. What kind of trigger can I use? Or is there motors that come with small voltage triggers and have there own power supply.
Thank you in advance
Pixord 126n
Axis 2420
