efFeb
- Dec 25, 2019
- 68
Hi!
I have several plate girders with long (3') openings. I have reinforced these for strength, but am also concerned about how this will affect deflections. At first I thought to use section wizard to design the section with the opening, keeping other dimensions constant, but I worry that over the 3' opening length, it would be unconservative to consider the added benefit I get to the I value from the parallel axis theorem based on the overall section depth. Has anyone run into a similar issue before or have any thoughts on this?
Thanks so much!
Thanks so much!
