Modeling From Photo
RoninB4
5
Hello to the collective. I've tried a "search" but couldn't come up with anything. The program Catia has a function that allows you to use a digital photograph and create a surfaces/solid model from this. There are some aspects about this that could be useful and I wondered if this could be done in Pro-e. I'm wondering if this is just as simple as importing the digital image (somehow) and workingt with a wireframe and datum curves. I saw this done in a video so I don't have more info about how the Catia function works. I was using 2001 and upgraded to Wildfire 3.0 Thanks in advance for all replies.
In Pro/ENGINEER you can use Pro/PHOTORENDER or ISDX to trace around a sketch. ISDX is the preferred method.
Bart Brejcha Chicago
DESIGN-ENGINE|EDUCATION
surfacing and Pro/CABLE training
Ronin,
I have tried this w/the Style feature once (WF2) and it imported okay. Lesson 12 (towards the end) has an example of how to do this and they use .gif files to create profile curves.
First time I've posted here so I hope you get all three files; Lesson 12.pdf, top.gif, and side .gif.
Hope this helps you.
 http://files.engineering.com/getfile.aspx?folder=754da774-e532-4553-abf2-5b0594c11788&file=Side_View.gif
Question - how exactly does CATIA "use a digital photograph and create a surfaces/solid model from this". Can you snap or link curves to the picture? I think pro/Concept was able to do this but not fully certain. ISDX could use this type of functionality.
We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
I want to thank all of you that took the time to reply, I'll be trying the ISDX suggestion. I can't answer how Catia does this, just saw it done once.
