BadgerPE
- Jan 27, 2010
- 500
Good morning all. Does anyone know if there is a referenced minimum modulus of elasticity to use for mircolam header/drag struts? I have searched the web quite a bit and haven't been able to come up with anything.
The reason I need this value is that I have a header that supports the floor above, but also needs to transfer axial load in a shear wall. So basically I need to quantify the amount of axial capacity the header has so I can check the interaction equation to verify that the header works in both bending and compression.
Thanks in advance for any help!
