bif
Chemical
- May 6, 2003
- 32
Is there an accepted/recommended method for sizing an overflow for an atmospheric tank where an independent vent line is also incorporated
The tank I am looking at contains hot water and has an independent vent line coming off the top. It also has an overflow set ~ 0.5 m from tan line coming out of the vertical vessel wall
I have seen various articles regarding self venting flows and Froude Nos. These appear to be applicable only when the vent is also the overflow?
If I size based on a self venting flow, the overflow line size seems excessive to me (nearly .08 m at a flow of 0.33m³/sec)
Is this correct, or can I reduce the size and accept that the flow doesn't have to be self venting as there is a separate vent line.
Is it accepatble to assume the overflow line is flooded to a set height and then work out the flow based on static head as the driving force
