Measurements to Excel
Wuzhee
Automotive
Jul 12, 2022
294
thread560-493796
Hi everyone,
Can someone with knowledge explain to me the attached code in the referenced thread?
I've got a small part where I measured surfaces. I want to export the Area parameters to an excel/csv. Preferably with the feature name.
Thank you all!
Wuzhee,
Here is a catscript that will get you close, probably a few tweaks to get exactly what you want.
This requires pre-selecting what you want to be exported to excel.
Script will export a screen shot, file name, file path & the pre-selected attributes.
The attributes will be listed in the order that they were selected.
Dim objGEXCELapp As Object
Dim objGEXCELwkBks As Object
Dim objGEXCELwkBk As Object
Dim objGEXCELwkShs As Object
Dim objGEXCELSh As Object
Dim PartDocument1
Dim oSelection As Integer
Dim xlCenter As Integer
Dim xlBottom As Integer
Sub CATMain()
On Error Resume Next
Set partDocument1 = CATIA.ActiveDocument
Set oselection =CATIA.ActiveDocument.Selection
Dim MyWindow As SpecsAndGeomWindow
Dim MyViewer As Viewer3D
Set MyWindow = CATIA.ActiveWindow
MyWindow.Layout = catWindowGeomOnly
Catia.ActiveWindow.Viewers.item(1).CaptureToFile 1, "C:\Temp\OBMSectionR1.emf"
'MyWindow.Layout = catWindowSpecsOnly
MyWindow.Layout = catWindowSpecsAndGeom
StartEXCEL
ExportParameter
UnLinkImage
End Sub
Sub StartEXCEL()
Err.Clear
Set objGEXCELapp = GetObject (,"EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set objGEXCELapp = CreateObject ("EXCEL.Application")
End If
objGEXCELapp.Application.Visible = TRUE
Set objGEXCELwkBks = objGEXCELapp.Application.WorkBooks
Set objGEXCELwkBk = objGEXCELwkBks.Add
Set objGEXCELwkShs = objGEXCELwkBk.Worksheets(1)
Set objGEXCELSh = objGEXCELwkBk.Sheets (1)
objGEXCELSh.Cells (4,"A") = "Attribute"
objGEXCELSh.Cells (4,"B") = "Value"
objGEXCELSh.Cells (2,"A") = (partDocument1.Path)
objGEXCELSh.Cells (3,"A") = (partDocument1.Name)
objGEXCELSh.Cells (2,"B") = "File Path"
objGEXCELSh.Cells (3,"B") = "File Name"
objGEXCELSh.Cells (2,"A").WrapText = True
objGEXCELSh.Cells (3,"A").WrapText = True
objGEXCELSh.Range("A1:B1").MergeCells = True
objGEXCELSh.Range("A1:B1").border
End Sub
Sub ExportParameter()
Dim i As Integer
For i = 1 To oSelection.Count
Dim oSelectedElement As SelectedElement
Set oSelectedElement = oSelection.Item(i)
Dim sElementName As String
sElementName = oSelectedElement.Value.Name
Dim sElementValue As String
sElementValue = oSelectedElement.Value.Value
objGEXCELSh.Cells (i+4,"A") = sElementName
objGEXCELSh.Cells (i+4,"B") = sElementValue
next
Const xlCenter = -4108
'Const xlBottom = -4107
Dim Choice As String
'display an input box asking for number format format choice
Choice = InputBox( "0 x."& vbCrLf & "1 x.x" & vbCrLf & "2 x.xx" & vbCrLf & "3 x.xxx", "Choose decimal places 0,1, 2 or 3", "2")
If Choice = 1 then
tolx = "0.0"
ElseIf Choice = 2 Then
tolx = "0.00"
ElseIf Choice = 0 Then
tolx = "0"
Else
tolx = "0.000"
End If
objGEXCELSh.Columns("B").NumberFormat = tolx
objGEXCELSh.Columns("A").ColumnWidth = 40
objGEXCELSh.Columns("B").ColumnWidth = 15
objGEXCELSh.Rows("1").RowHeight = 150
objGEXCELSh.Rows("4").RowHeight = 25
objGEXCELSh.Columns("A:B").HorizontalAlignment = xlCenter
objGEXCELSh.Range("A4:B4").Font.Bold = True
objGEXCELSh.Range("A4").Font.Size = 20
objGEXCELSh.Range("B4").Font.Size = 20
objGEXCELSh.Range("A2").Font.Size = 10
objGEXCELSh.Range("A3").Font.Size = 10
objGEXCELSh.Range("A2:B2").Font.color = vbBlue
objGEXCELSh.Range("A3:B3").Font.color = vbBlue
'add borders to cells in excel
Dim rowcount as Integer
rowcount = oSelection.Count + 4
objGEXCELSh.Range("A4:B" & rowcount).Borders.LineStyle = 1
objGEXCELSh.Range("A4:B4").Interior.ColorIndex = 15
objGEXCELSh.Range("A2:B3").Interior.ColorIndex = 4
objGEXCELSh.Range("A4:B" & rowcount).Borders(7).Weight = 4
objGEXCELSh.Range("A4:B" & rowcount).Borders(8).Weight = 4
objGEXCELSh.Range("A4:B" & rowcount).Borders(9).Weight = 4
objGEXCELSh.Range("A4:B" & rowcount).Borders(10).Weight = 4
' Add Picture to cells a1 and b1
Dim rng As Range
Set rng = objGEXCELSh.Range("A1:B1")
Dim pic As Picture
Dim v As Variant
set pic = objGEXCELSh.Pictures.Insert("C:\Temp\OBMSectionR1.emf")
With pic
.ShapeRange.LockAspectRatio = msoTrue
.Height = rng.Height -6 'size 6 smaller than cells for border to show
.Width = rng.Width -6 'size 6 smaller than cells for border to show
End With
End Sub
Sub UnLinkImage()
objGEXCELSh.Shapes("Picture 2").Cut
objGEXCELSh.Range("A1:B1").Select
objGEXCELSh.Pictures.Paste.Select
Dim pic3 As Picture
Set pic3 = objGEXCELSh.Shapes("Picture 3")
pic3.Line.Weight = 2
pic3.Left = 3 'shift image 3 to center image in cell
pic3.Top = 3 'shift image 3 to center image in cell
End Sub
