BRIS
- Mar 12, 2003
- 525
I need to regulate a flow control valve from a pressure transducer located 9 miles downstream. For safety reasons the client requires the communication is hard wired. I am advised that the length is too long to send a signal from the pressure transducer to the control valve via cable (hard wire).
What is the maximum length that we can send a signal by cable ? Can I provide an amplifier to boost the signal? Cost is important - how much am I looking at to send a hard wired analogue signal from a pressure transducer to a flow control valve over a length of 9 miles. ?.
