milkshakelake
- Jul 15, 2013
- 1,176
How do you specify the material of round soldier piles? I'm speaking to a soldier pile supplier. They explained:
1. Prime Pipe is made using API 5CT specification, which has strict mechanical and chemical properties.
2. Some stuff isn't good enough for that. This is called Mill Secondary Material. That's what soldier piles are made of. Thus, they don't have a material classification.
3. They ship with material testing reports attesting to their yield strength, usually 80 ksi or more. This is the main thing that designers need.
I agree with them that I only care about the ksi when it comes to soldier piles, or really any type of steel. The problem is that an official with authority is rejecting my drawings calling for soldier piles to have minimum 80 ksi design strength. He's saying that there needs to be a material specification attached to it.
Is there any code I can use that says that I don't need to specify the material of a soldier pile, only its strength?
The closest I can get is from my local code based on IBC, which doesn't help:
2203.1 Identification. Identification of structural steel elements shall be in accordance with the requirements contained in AISC 303. [...] Other steel furnished for structural load-carrying purposes shall be properly identified for conformity to the ordered grade in accordance with the specified ASTM standard or other specification and the provisions of this chapter. Where the steel grade is not readily identifiable from marking and test records, the steel shall be tested to determine conformity to such standards.
