Macro 1
malis
31
I have a design table inserted into my assembly that controls the motion of a skeleton sketch. I'm using the design table to drive one dimesion while getting the results of another dimension. The problem is that you have to activate each configuration in order for the design table to record the result of the second dimension. In my case i have 70 configs. Does anyone have a Macro that will do this process for me? or is there an easier way to get this information.
Can you explain a bit more about what you are trying to do & how you are doing it?
Can you not build formulae/equations into the DT which populate the other configuration dimensions?
[cheers]
Helpful SW websites faq559-520​
How to find answers ... faq559-1091​
I made my DT's fully automated, using Excel formula's and equations... I never had any problems such as that... but you do have to activate the config before the model would update to the new specs given for each COnfig.
Scott Baugh, CSWP [pc2]
faq731-376
If you want to force a rebuild of every configuration there is a macro in the help to do that. Here it is:
SolidWorks API Help said:
Forcibly Rebuild All Configurations Example (VB)
This example shows how to forcibly rebuild all of the configurations in a SolidWorks document.
Code:
Option Explicit
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim nStart                  As Single
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Debug.Print "File = " + swModel.GetPathName
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        bShowConfig = swModel.ShowConfiguration2(sConfigName)
        nStart = Timer
        bRebuild = swModel.ForceRebuild3(False)
        Debug.Print "  Config       = " & sConfigName
        Debug.Print "    ShowConfig = " & bShowConfig
        Debug.Print "    Rebuild    = " & bRebuild
        Debug.Print "    Time       = " & Timer - nStart & " s"
    Next i
End Sub
Thanks Handleman, That is exactly what i was looking for.
