SpartanZ32
Automotive
- Apr 28, 2009
- 5
Hi, ladies and gents...I'm a total newbie to this forum, and not even an engineer. However, I am quite the "tinkerer", and love designing and bulding new things.
So with that being said, I am currently working on a 1990 Nissan 300zx....doing an engine swap (V8). The issue I'm having is that the steering rack is mounted a little too high on the front crossmemer, and it is taking up the space where the oil pan needs to be. I have no problem lowering the rack the 2.5"-3", but my concern is bumpsteer.
Will lowering the rack yield negative results (ie: bumpsteer, etc)? One thing that crossed my mind is that if I lower the rack 2.5", can I "correct" this by adding a 2.5" spacer to the tie rod end where it meets the knuckle? In my head, this will keep the same geometry as factory. Am I right or wrong?
I know this might be hard to answer from just reading my post. I can provide pictures if necessary.
Thanks in advance!!!! Any help will be gratly appreciated.
