onteng
- Jul 2, 2001
- 20
We have completed an analysis of an existing pre-eng building built in 1975. The frames were overstressed by 150% under unbalanced loads. The purlins were overstressed by over 100% under normal snow load and finally the girts were overstressed by 100% under wind. Once reported to the client, two separate engineering firms completed peer reviews, both agreeing with our conclusions.
The problem is the second firm recommended a load test. I have been asked to comment on their procedure. How is it possible to load test such a building without failing the structure or if local testing is done how you prevent adjacent frames from contributing to the resistance.
I have talked to other engineers who all agree that load testing does not seem reasonable. Your comments would be appreciated.
Onteng
Onteng
